[Qgis-user] R: using field calculator to do a spatial update for a table usingdata from an overlapping geometry.
enricofer
enricofer at gmail.com
Tue Oct 28 10:19:30 PDT 2014
Thank you,
I realized that I was in the right way when i seen new expression functions introduced by new 2.6 version. There will be a new getfeature that has the same goal of the one called dbvalue implemented by the plugin.
A Great improve will come also from the memory field new feature that allows to calculate in the fly new fields without having to modify table structure. And here a set of function to reference to other layers would be very useful.
As I want to extend the reference functions set I would be interested in suggestion and testing feedback.
Regards
Enrico ferreguti
----- Messaggio originale -----
Da: "Järnefelt Jouko [via OSGeo.org]" <ml-node+s1560n5169947h26 at n6.nabble.com>
Inviato: 28/10/2014 15:03
A: "enricofer" <enricofer at gmail.com>
Oggetto: Re: using field calculator to do a spatial update for a table usingdata from an overlapping geometry.
Enrico: Nice work I have to say! I think this kind of functionality should be part of the QGIS core. Or atleast I'm missing a way to do "join attributes by location" kind of task in processing toolbox as well as in geographical modeler.
Cheers,
Jouko
-----Alkuperäinen viesti-----
Lähettäjä: [hidden email] [mailto:[hidden email]] Puolesta Damien Stephens
Lähetetty: 24. lokakuuta 2014 8:50
Vastaanottaja: enricofer; [hidden email]
Aihe: Re: [Qgis-user] using field calculator to do a spatial update for a table using data from an overlapping geometry.
Enrico you have made my day ! - much appreciated.
I will have a look at it and get back to you on how I progress.
Thanks Again
Damien
-----Original Message-----
From: [hidden email] [mailto:[hidden email]] On Behalf Of enricofer
Sent: Thursday, 23 October 2014 6:14 PM
To: [hidden email]
Subject: Re: [Qgis-user] using field calculator to do a spatial update for a table using data from an overlapping geometry.
You are lucky.
I was developing a plugin with reference functions that fits to solve similar problems.
I see your question and I implemented a dbwithin function You can get a development version from github:
https://github.com/enricofer/refFunctions/archive/master.zip
put the inside directory refFunctions-master in your plugin directory (typical .qgis/python/plugins in your user profile directory if you work in
windows)
then restart qgis
If everything ok you will find under field calculator dialog a new group of experimental functions called 'reference' with a function dbwithin:
<http://osgeo-org.1560.x6.nabble.com/file/n5169107/reffunc.png>
Syntax
dbwithin(targetLayer,targetField)
Arguments:
targetLayer; the name of a currently loaded layer, for example 'myLayer'.
targetField; a field in target layer we want as result when source feature is within target feature, for example 'myField'. If targetField is equal to '$geometry' The WKT geometry of targetFeature willbe retrieved
Number of feature tested is limited to 100000 to avoid time wasting loops
Example:
dbwithin('targetLayer','TargetField')
dbwithin('targetLayer','$geometry')
Let me know if that resolvs
PS: Qgis guys are releasing 2.6 version that contains some new expression funtions very very interesting for you......
Bye.
Enrico
View this message in context: http://osgeo-org.1560.x6.nabble.com/using-field-calculator-to-do-a-spatial-update-for-a-table-using-data-from-an-overlapping-geometry-tp5169056p5169107.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
Qgis-user mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/qgis-user
[hidden email]
[hidden email]
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/using-field-calculator-to-do-a-spatial-update-for-a-table-using-data-from-an-overlapping-geometry-tp5169056p5169947.html
To unsubscribe from using field calculator to do a spatial update for a table using data from an overlapping geometry., click here.
NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/R-using-field-calculator-to-do-a-spatial-update-for-a-table-usingdata-from-an-overlapping-geometry-tp5170023.html
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141028/4f200c20/attachment.html>
