[Qgis-user] error_ R_home range
    Sergio Vignali
    vignalisergio30 at gmail.com
    Wed Oct 29 06:34:37 PDT 2014
Hi Emiliano,
Have you installed adehabitatHR package?
all the best
Sergio
2014-10-29 14:30 GMT+01:00 Emiliano Manzo <emiliano.manzo at ethoikos.it>:
> Hi
> i have tried to use R home range, i have installed adhabitat on R and
> after i had tried to run h kernel but i received this error message and i
> don’t know what i can do.
> I used Mac os X Qgis 2.4
> Oooops! The following output layers could not be open
>    - Home_ranges:
>    /var/folders/zw/bp2757r12_s4_rryzp2fjblw0000gn/T/processing/eb692106bf2b4c75b891f7cd3a67c6bc/Homeranges.shp
> The above files could not be opened, which probably indicates that they
> were not correctly produced by the executed algorithm
> Checking the log information might help you see why those layers were not
> created as expected
> This algorithm requires R to be run. A test to check if R is correctly
> installed and configured in your system has been performed, with the
> following result:
> R seems to be correctly installed and configured
> The script you have executed needs the following packages:
>    - adehabitatHR
> Make sure they are installed in your R environment before trying to
> execute this script.
> Is anybody can help me?
> Thank you
> Emiliano
> Qgis-user mailing list
Sergio Vignali
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141029/02461855/attachment.html>
