[Qgis-user] low CPU on python plugin computation - an explanation ?
Carlos Cerdán
sig.upagu at gmail.com
Wed Oct 29 10:39:29 PDT 2014
It's useful information, thank you Alain
2014-10-29 11:48 GMT-05:00 Alain Gauthier <alain.gauthier at eaucea.fr>:
> Hello,
> I found a workaround to my problem : the computation I am performing is
> done on a layer open from a network file.
> So I copied the files on my local computer disk and the computation time
> became normal, with a normal CPU usage.
> In order to understand the problem, I had a look to questions on slow
> network access trouble with QGIS. I think my problem is related to that
> one : http://hub.qgis.org/issues/6448
> In fact if I try to perform a simple "spatial query" with Qgis onto a
> layer opened for a network file, the computation is very slow and does
> not use more than few percents of CPU. The same query done on a layer
> opened from a local disk file is normaly performed.
> I hope this could help anyone facing this performance problem.
> Thank you for your attention
> Alain Gauthier
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141029/adcf3f30/attachment.html>
