[Qgis-user] Labels not visible when setting them programmatically.
Casper Børgesen (CABO)
CABO at NIRAS.DK
Wed Apr 1 05:19:35 PDT 2015
No the triggerRepaint() didn't work, just to clarify that I tried that :)
Regards, Casper
-----Original Message-----
From: Werner Macho [mailto:werner.macho at gmail.com]
Sent: 1. april 2015 13:52
To: Casper Børgesen (CABO)
Cc: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Labels not visible when setting them programmatically.
Hi!
I thought maybe it is the
triggerRepaint()
but it was just a guess.
regards
Werner
On Wed, Apr 1, 2015 at 1:48 PM, Casper Børgesen (CABO) <CABO at niras.dk> wrote:
> Hi Werner
> Sadly no, it does not.
> Regards, Casper
> Sent: 1. april 2015 13:43
> Hi,
> does
> https://github.com/mach0/qchainage/blob/master/chainagetool.py
> line 150 ff help you?
> regards
> Werner
> On Wed, Apr 1, 2015 at 1:25 PM, Casper Børgesen (CABO) <CABO at niras.dk> wrote:
>> I’m trying to programmatically set and enable labelling on a layer
>> using Python in QGis 2.9.0.
>> label = QgsPalLayerSettings()
>> label.readFromLayer(myLayer)
>> label.enabled = True
>> label.fieldName = 'myField'
>> # Just to change something clearly visible.
>> label.textColor = QColor(255,0,0,255)
>> label.writeToLayer(myLayer)
>> This doesn’t enable labelling, but if I enter the Layer Properties on
>> myLayer, everything looks okay and when pressing Apply, the labels
>> become visible.
>> Is there something I need to set to avoid having to manually click
>> Apply to get the labels visible?
>> Calling iface.mapCanvas().refresh() afterwards doesn’t work.
>> Regards, Casper
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
