[Qgis-user] Background to Lable
    Andreas Neumann
    a.neumann at carto.net
    Wed Apr  1 23:08:39 PDT 2015
Hi Nikhil,
I tried this in QGIS 2.8 and in QGIS master and cannot reproduce your
problem.
Can you share your settings? Perhaps a screenshot of the label settings,
in particular the tab with the "Placement" and the "Backround" options?
If you label the lines directly - as I just did - make sure you use
"horizontal" in the placement options, and not "curved".
Andreas
On 02.04.2015 03:42, Nikhil Murarka wrote:
> Hello,
> I am using QGIS 2.6 and I am trying to add the SVG image to the label
> basically the route shield as background to route number label but
> problem is that SVG image is added per character so If my route number
> is '456' 3 route shield are added.
> Is there any work around this to add just one route shield for my
> route number 456?
> Thanks,
> Nikhil
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150402/a839707f/attachment.html>
