[Qgis-user] label Placement data defined properties
    Andreas Neumann
    a.neumann at carto.net
    Tue Apr  7 02:09:41 PDT 2015
Hi Nikhil,
No - this is not yet possible.
Most label properties are exposed to data-defined properties - but this
particular is not. There was never a demand for this feature.
If you need this, you can contract a developer to expose this property
to be data-defined.
Alternatively, you can load the layer two times, with two different
settings and two scale ranges. Not so nice - but a possible workaround.
Andreas
On 03.04.2015 14:48, Nikhil Murarka wrote:
> Hello,
> Is there any way I can define data define properties for label. Such
> that when the scale less than x it should be curve else it should be
> horizontal.
> I can write an expression for this but there is no expression for
> placement in label tab for layer.
> Thanks,
> Nikhil
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150407/56de6370/attachment.html>
