[Qgis-user] qgis-server vs layer id
Andreas Neumann
a.neumann at carto.net
Thu Apr 9 00:03:13 PDT 2015
I would prefer if this issue could be fixed within QGIS Server. I also
have the same problem when copying projects.
We could combine this effort with a more persistent project/layer cache
of QGIS server, so the cache would survive Apache restarts.
I would be available for co-financing if others would join the effort.
Andreas
On 09.04.2015 08:53, Nathan Woodrow wrote:
> Hey Burghardt,
> As a workaround for now it's pretty easy to read the xml file and
> replace the layer ids using Python. QGIS doesn't care about the
> format of the id as long as it's a strings so you could replace them
> all with a GUID if you wanted.
> - Nathan
> On Thu, 9 Apr 2015 at 16:46 <Burghardt.Scholle at stadt.wolfsburg.de
> <mailto:Burghardt.Scholle at stadt.wolfsburg.de>> wrote:
> Dear list,
> I enjoy working with templates for QGIS projects. This brings when
> working with QGIS Desktop many advantages, but leads to problems
> with the QGIS Web Client. When I save a project file under a
> different name, the id of the layer, unfortunately, is maintained.
> If I use both project files in the qgis-server, this creates
> problems with caching of layer. That is particularly evident when
> identical layer named differently or otherwise be symbolized.
> This topic is discussed on several occasions in the past [1,2] and
> has been referred to as "bug" or "limitation". In [2] it's said
> that the combination of project name and layer ID could be a
> solution for the problem. Up to and including version 2.8.1, the
> change has not yet been carried out. Is there an effort to change
> the creation of the layer ID in a future release?
> Kind regards
> Burghardt
> [1]
> http://osgeo-org.1560.x6.nabble.com/Qgis-server-returns-map-from-another-project-that-is-defined-in-URL-td5153101.html#a5153150
> [2] http://hub.qgis.org/issues/7956
> mailto:burghardt.scholle at stadt.wolfsburg.de
> <mailto:burghardt.scholle at stadt.wolfsburg.de>
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150409/6978572d/attachment.html>
