[Qgis-user] Point pattern analysis
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Mon Apr 13 04:38:19 PDT 2015
Your welcome,
You can always install the old version of qgis so that the SDA4PP plugin will work. Older versions are available.  You could also update the plugin if you are good in python or contact the developer directly.
Cheers
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112  Fax: 514.381.4995
www.archeotec.ca
On Apr 12, 2015 3:44 PM, "Niccolò Marchi [via OSGeo.org]	" <ml-node+s1560n5200964h45 at n6.nabble.com> wrote:
	thank you very much Nicolas, I'll take a look asap!
it's a pity to have such a tool (SDA4PP) within qgis and not being able
to use it :) I really hope in some way it will be integrated or updated.
all the best,
Niccolò
Qgis-user mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/qgis-user
		If you reply to this email, your message will be added to the discussion below:
		http://osgeo-org.1560.x6.nabble.com/Point-pattern-analysis-tp5200837p5200964.html
		To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
		To unsubscribe from Quantum GIS - User, click here .
		NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Point-pattern-analysis-tp5200837p5201046.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150413/ff5a743f/attachment.html>
