[Qgis-user] QGIS 64-bit, Processing Toolbox and Grass 7
Saulteau Don
sault.don at gmail.com
Tue Apr 14 14:29:38 PDT 2015
There's a crowdfunding campaign[1] underway to get QGIS updated for GRASS 7.
So yes, like Jose pointed out, some of the grass7 tools in processing will
have errors.
You can compile QGIS without any of the cmake options for GRASS, because I
think those are only if you want to have the GRASS plugin (that toolbar).
If you want GRASS 7 in Processing, you can update the providers in the
processing options and also double check that the needed env vars[2][3] for
GRASS exist.
Upgrading the toolbar for GRASS7 support is also part of the crowd funding
too.
[1] http://www.gissula.eu/qgis-grass-plugin-crowdfunding/
[2] http://grass.osgeo.org/grass70/manuals/variables.html
[3]
http://grasswiki.osgeo.org/wiki/Working_with_GRASS_without_starting_it_explicitly
On Mon, Apr 13, 2015 at 2:08 AM, José Antonio Barreña Cayuela <
jabarcay at gmail.com> wrote:
> Adrian,
> My solution was to install grass64 and edit qgis pkbuild for this grass
> version (look commnents in https://aur.archlinux.org/packages/qgis/).
> The grass does not work environment. Processing seems to work but in tests
> I've done gives me errors.
> El 12/04/15 a las 21:30, Adrian Wooster escribió:
> I'm finding I need to use the 64-bit version of QGIS for some of my
> bigger models but I miss the ability to use Grass 7 without having to
> drop out to load it natively.
> I recognise that there are issues for the developers in embedding
> Grass 7 within the OSGEO4Win 64-bit package, but is anyone aware of a
> mechanism to configure the 64-bit version of QGIS (2.8/9) to load
> Grass 7 modules from a standalone installation via the Processing
> Toolbox?
> I have both installed on my system but haven't been able to find a
> set-up where Processing will recognise the Grass 7 installation.
> Regards,
> Adrian
> Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-user
> *Biólogo (botánico). Servicios Medioambientales*
> *+34 677 811 883* · jabarcay at gmail.com
> [image: skype] [image: linkedIn]
> <http://es.linkedin.com/pub/jos%C3%A9-antonio-barre%C3%B1a-cayuela/26/936/15a/>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150414/bf64ddd6/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150414/bf64ddd6/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150414/bf64ddd6/attachment-0001.png>
