[Qgis-user] Problem with raster calculator
George Silva
georger.silva at gmail.com
Wed Apr 15 19:29:53 PDT 2015
Raster calculator has a nasty bug on 26 and 28 that its truncating values.
I dont have The correct number but I suggest you do a search on The
bugtracker and add dome weight to it.
it looks serious enough and its a blocker but without any comments.
On Wednesday, April 15, 2015, Michael Treglia <mtreglia at gmail.com> wrote:
> Hi All,
> Was encountering a similar problem with Raster Calculator [albeit a bit
> different] just yesterday - I had a layer that had values ranging ~0-1000
> (integers). I wanted the layer to represent probability values (ranging
> 0-1), so I used the raster calculator to divide it by 1000.
> I ended up with 'nan' values displayed as the max and min on the Layers
> pane and when I try to get into the properties I get a "Bad allocation"
> message. Using the 'Identify Features' tool, the values look appropriate,
> but I can't adjust the style or anything.
> I ended up doing what I needed in R for now, but it would be great to work
> through this issue - I'm open to any suggestions, or can send the data in
> case others want to test.
> Using QGIS 2.8.1 64-bit on Win7.
> Cheers,
> mike
> On Wed, Apr 15, 2015 at 4:30 AM, Ricardo Filipe Soares Garcia da <
> ricardo.garcia.silva at gmail.com
> <javascript:_e(%7B%7D,'cvml','ricardo.garcia.silva at gmail.com');>> wrote:
>> Hi Jesus
>> Perhaps your input layer has no values that match the >= 73 condition?
>> I can reproduce this behaviour if I use a layer in which pixel values go
>> up to 50 and I ask for pixels >= 60.
>> Otherwise, if the input layer has values above the threshold, it seems
>> strange and I cannot seem to reproduce it here (QGIS 2.8.1)
>> On Wed, Apr 15, 2015 at 8:58 AM, Jesus Munoz <jesusmunozserrano at gmail.com
>> <javascript:_e(%7B%7D,'cvml','jesusmunozserrano at gmail.com');>> wrote:
>>> Good morning list!!
>>> I am trying to do a cloud mask for a Landsat image based on the values
>>> of the pixels where the clouds are found. I am using the raster calculator
>>> for this purpose by introducing the expression:
>>> (“Band 1 layer name" >= 73) * "Band 1 layer name”
>>> So basically, I am trying to obtain a layer in which all pixels with a
>>> value lower than 73 are removed.
>>> However, after calculating this expression I only get an empty raster
>>> layer, only visible in the layers panel and populated only by “nan” values.
>>> Does anybody know what am I doing wrong???
>>> Jesus
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> <javascript:_e(%7B%7D,'cvml','Qgis-user at lists.osgeo.org');>
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> ___________________________ ___ __
>> Ricardo Garcia Silva
George R. C. Silva
SIGMA Consultoria
http://www.consultoriasigma.com.br/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150415/3f48f386/attachment.html>
