[Qgis-user] QGIS FreeBSD port and qgis-server
James Keener
jim at jimkeener.com
Sun Apr 19 06:22:16 PDT 2015
GREP HARDER!
:) I was specifically referring to the FreeBSD port's Makefile. Ports
are a collection of source-based packages. Essentially, on your system
you get the base tools and Makefile and pkg-plist for every program.
Those files tell the base tools how to get a copy of the source, how to
set options in it, which other ports are needed to compile this one, &c.
Rainer, the port maintainer, replied and said he was fixing the issue.
Jim
On 04/19/2015 05:07 AM, Jürgen E. Fischer wrote:
> Hi James,
> On Sun, 19. Apr 2015 at 01:02:23 -0400, James Keener wrote:
>> I am interested in being able to use the qgis mapserver on FreeBSD 10.1.
>> I enabled the mapserver option via `make config-recursive` and built the
>> port via `make install`. I cannot seem to find the fcgi executable in
>> the build output or in the pkg-plist file. I see
>> "WITH_MAPSERVER:BOOL=TRUE" being passed into CMakeCache.txt
> What plist file? The only reference to WITH_MAPSERVER I find in master
> is
> $ git grep WITH_MAPSERVER
> ChangeLog: * rename cmake option WITH_MAPSERVER to WITH_SERVER
> Jürgen
> Qgis-user mailing list
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150419/c9080735/attachment.sig>
