[Qgis-user] GDAL Fill nodata Algorithm
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Thu Apr 23 07:05:28 PDT 2015
Not sure. Where do you see that? A Mask is usually a raster file with zeros and ones. It will permit you to cut or modify another raster to a specific shape by multiplying it to the mask. I imagine a validity mask is asked if you what to first validate an area you want to modify.
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112 Fax: 514.381.4995
www.archeotec.ca
On Apr 23, 2015 8:36 AM, "Larissa Junek [via OSGeo.org]" <ml-node+s1560n5202645h56 at n6.nabble.com> wrote:
Hello Nicolas,
can you tell me what the validity mask is and what's it for?
Am Thu, 23 Apr 2015 13:31:56 +0200
schrieb Larissa Junek < [hidden email] >:
> Hello Nicolas,
> I have further questions concerning the use of the algorithm!
> Am Wed, 22 Apr 2015 12:00:03 -0700 (PDT)
> schrieb Nicolas Cadieux < [hidden email] >:
> > Hi,
> > I believe so but I usually use the .tiff format. Just
> > make sure the "null data" value is specified in the raster. You can
> > do that under the "save as". Specifying additional null
> > value in the layer properties does not work.
> Is it right that the no-data values must be represented by 0 so that
> the interpolation works properly then?
> Nicolas
> > Cadieux M.Sc. Les Entreprises Archéotec inc.  8548, rue
> > www.archeotec.ca On Apr 22, 2015 9:50 AM, "Larissa Junek [via
> > OSGeo.org]" < [hidden email] >
> > wrote:
> > Hello,
> > does someone know if you can use any GDAL-supported raster layer
> > with the Processing Fill nodata Algorithm?
> > Kinde regards,
> > Larissa
> > Qgis-user mailing list
> > [hidden email]
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> > If you reply to this email, your message will be
> > added to the discussion below:
> > http://osgeo-org.1560.x6.nabble.com/GDAL-Fill-nodata-Algorithm-tp5202470.html
> > To start a new topic under Quantum GIS - User, email
> > ml-node+s1560n4125267h38@n6.nabble.com To unsubscribe from
> > Quantum GIS - User, click here . NAML
> > View this message in context:
> > http://osgeo-org.1560.x6.nabble.com/GDAL-Fill-nodata-Algorithm-tp5202470p5202536.html > > Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> [hidden email]
> http://lists.osgeo.org/mailman/listinfo/qgis-user --
Geoinformatikbüro Dassau GmbH
Rethelstrasse 153
D - 40237 Düsseldorf
Tel: +49-211-69937750
Fax: +49-211-69937751
Mobile: +49-171-4687540
http://www.gbd-consult.de Registergericht: Amtsgericht Düsseldorf, HR B 74022
Geschäftsführer: Otto Dassau
[hidden email]
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/GDAL-Fill-nodata-Algorithm-tp5202470p5202645.html
To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
To unsubscribe from Quantum GIS - User, click here .
NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/GDAL-Fill-nodata-Algorithm-tp5202470p5202680.html
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150423/d819b22b/attachment.html>
