[Qgis-user] GDAL Fill nodata Algorithm
    Nicolas Cadieux
    nicolas.cadieux at archeotec.ca
    Fri Apr 24 06:45:13 PDT 2015
Probably not.  I use one under the raster menu, not the processing tools. If you click the advanced menu in the processing toolbox, they should be organized by provider and you will see who makes it. Grass, gdal, saga...
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112  Fax: 514.381.4995
www.archeotec.ca
On Apr 24, 2015 5:01 AM, "Larissa Junek [via OSGeo.org]" <ml-node+s1560n5202792h13 at n6.nabble.com> wrote:
	When i use QGIS 2.8 and open the Fill nodata Algorithm from Processing
there are the following menus:
Input layer, Search distance, Smooth iterations, Band to operate on,
Validity mask, DO not use default validity mask, Filled.
Are we talking about the same application?
Kind regards,
Larissa
Am Thu, 23 Apr 2015 07:05:28 -0700 (PDT)
schrieb Nicolas Cadieux < [hidden email] >:
> Not sure.  Where do you see that?  A Mask is usually a
> raster file with zeros and ones.  It will permit you to cut or
> modify another raster to a specific shape by multiplying it to the
> mask.  I imagine a validity mask is asked if you what to first
> validate an area you want to modify.  Nicolas Cadieux M.Sc. Les
> Entreprises Archéotec inc.  8548, rue Saint-Denis
> Montréal H2P 2H2 Téléphone: 514.381.5112
>  Fax: 514.381.4995 www.archeotec.ca On Apr 23, 2015 8:36 AM,
> < [hidden email] > wrote:
> 	Hello Nicolas,
> can you tell me what the validity mask is and what's it for?
> Am Thu, 23 Apr 2015 13:31:56 +0200
> schrieb Larissa Junek < [hidden email] >:
> > Hello Nicolas,
> > I have further questions concerning the use of the algorithm!
> > Am Wed, 22 Apr 2015 12:00:03 -0700 (PDT)
> > > Hi,
> > > I believe so but I usually use the&nbsp; .tiff
> format.&nbsp; Just > > make sure the "null data"
> value is specified in the raster. You can > > do that under the
> "save as". Specifying additional null > >
> value&nbsp;&nbsp; in the layer properties does not work. >
> Is it right that the no-data values must be represented by 0 so that
> > the interpolation works properly then? >
> >  Nicolas
> > > Cadieux M.Sc. Les Entreprises Arch&#233;otec
> inc.&#160; 8548, rue > > Saint-Denis Montr&#233;al H2P
> 2H2 > > T&#233;l&#233;phone:&#160;514.381.5112
> &#160;Fax: 514.381.4995 > > www.archeotec.ca On Apr 22,
> 2015 9:50 AM, &quot;Larissa Junek [via > >
> OSGeo.org]&quot; &lt; [hidden email] &gt; > >
> wrote: > >
> > > 	Hello,
> > > does someone know if you can use any GDAL-supported raster
> layer > > with the Processing Fill nodata Algorithm?
> > > Kinde regards,
> > > Larissa
> > > _______________________________________________
> > > Qgis-user mailing list
> > > [hidden email]
> > > http://lists.osgeo.org/mailman/listinfo/qgis-user
> > > 		If you reply to this email, your message
> will be > > added to the discussion below:
> http://osgeo-org.1560.x6.nabble.com/GDAL-Fill-nodata-Algorithm-tp5202470.html > > > > > 		To start a new topic under
> Quantum GIS - User, email > >
> ml-node&#43;s1560n4125267h38&#64;n6.nabble.com To unsubscribe
> from > > Quantum GIS - User, click here . NAML > >
> > > View this message in context:
> http://osgeo-org.1560.x6.nabble.com/GDAL-Fill-nodata-Algorithm-tp5202470p5202536.html > > > Sent from the Quantum GIS - User mailing list archive at
> Nabble.com. > _______________________________________________ >
> Qgis-user mailing list > [hidden email] >
> http://lists.osgeo.org/mailman/listinfo/qgis-user  --
> Geoinformatikbüro Dassau GmbH Rethelstrasse 153
> D - 40237 Düsseldorf
> Tel: +49-211-69937750
> Fax: +49-211-69937751
> Mobile: +49-171-4687540
> http://www.gbd-consult.de  Registergericht: Amtsgericht Düsseldorf, HR
> B 74022 Geschäftsführer: Otto Dassau
> [hidden email]
> 		If you reply to this email, your message will be
> http://osgeo-org.1560.x6.nabble.com/GDAL-Fill-nodata-Algorithm-tp5202470p5202645.html
> 		To start a new topic under Quantum GIS - User, email
> ml-node+s1560n4125267h38@n6.nabble.com To unsubscribe from
> http://osgeo-org.1560.x6.nabble.com/GDAL-Fill-nodata-Algorithm-tp5202470p5202680.html > Sent from the Quantum GIS - User mailing list archive at Nabble.com.
Rethelstrasse 153
http://www.gbd-consult.de Registergericht: Amtsgericht Düsseldorf, HR B 74022
[hidden email]
		If you reply to this email, your message will be added to the discussion below:
		http://osgeo-org.1560.x6.nabble.com/GDAL-Fill-nodata-Algorithm-tp5202470p5202792.html
		To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
		To unsubscribe from Quantum GIS - User, click here .
		NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/GDAL-Fill-nodata-Algorithm-tp5202470p5202844.html
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150424/c66733e6/attachment.html>
