[Qgis-user] Heatmap invbisible
Luís Miguel Royo Pérez
luis.miguel.royo at gmail.com
Mon Apr 27 06:15:23 PDT 2015
I think the layer has an incorrect SRC, so to correct it you can use
the tool "warp" form GDAL algorithms and fix it. Note that apparently
the SRC is ok. But if you reproject to the _/same SRC/_, the layer will
place in the correct position.
Hope it helps!!
On 27/04/15 14:33, dongha5 wrote:
> have "zoom to layer" in TOC, you will find heatmap. So, It has
> different coordinate as
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150427/f993e91c/attachment.html>
