[Qgis-user] show labels only, if objects are activated/visible
Andreas Neumann
a.neumann at carto.net
Thu Apr 30 01:50:23 PDT 2015
Hi Bernhard,
Yes - we "sort of" have "rule based" labeling with the data-defined
properties and conditions. But for very complex labeling it is a bit
hard to track. The rules are so distributed in different
places/properties that it is hard to get an overview what is really
going on.
I mean the UI of the rule-based symbology is nicer and allows to change
multiple graphical properties of the same rule at once.
There is certainly room for improvements.
A coupling of rendering and labeling would be quite interesting (esp.
for the case Otto is mentioning where users want to selectively
enable/disable rules/categories), I think - but I don't know if it is
technically solvable (or how hard it is).
Andreas
On 30.04.2015 10:37, Bernhard Ströbl wrote:
> Hi Andreas,
> don't we have rule-based labelling?
> CASE WHEN <condition> THEN 'bla' ELSE 'blub' END
> Problem is that you may have to rewrite all the rules that you already
> have written in the rule-based style.
> Bernhard
> Am 30.04.2015 10:21, schrieb Andreas Neumann:
>> Hi Otto,
>> I don't think that this is possible. As far as I know the labeling is
>> totally disconnected from the symbology. Only global filters on the
>> whole layer (the filter in the general tab in the layer properties) is
>> honored by both labeling and the rest of the symbology. The rest is
>> totally disconnected.
>> I can see value in what you want, but I doubt it is easily possible.
>> It would also help if we would have rule based labeling, so we could at
>> least apply similar rules to the labels as we apply to the symbology of
>> features.
>> Larry probably knows more about that.
>> Andreas
>> On 30.04.2015 09:44, Otto Dassau wrote:
>>> Hi,
>>> is it possible to show labels only, if the objects are
>>> activated/visible?
>>> I use the rule based renderer with two nested rules, both categorized
>>> rendering, like:
>>> Cat 1
>>> Road 1
>>> Cat 2
>>> |_ Lukas
>>> |_ Frank
>>> |_ Markus
>>> |_ Georg
>>> Road 2
>>> |_ John
>>> |_ Leo
>>> |_ Herbert
>>> If I deactivate labeling for some values in the first categorized
>>> rendering (Cat 1), objects and labels are invisible. But if I
>>> deactivate
>>> labeling for some values in the second categorized rendering (Cat 2),
>>> objects are invisible but labels are still shown.
>>> Is there a way how to solve this in the rule based renderer?
>>> Thanks a lot
>>> Otto
> __________ Information from ESET Mail Security, version of virus
> signature database 11555 (20150430) __________
> The message was checked by ESET Mail Security.
> http://www.eset.com
> Qgis-user mailing list
