[Qgis-user] Field expression for file name?
    nicolas.cadieux at archeotec.ca
    Thu Apr 30 13:28:08 PDT 2015
I am building an index of a LiDar project (using .las files). I can use
lasboundary.exe to create .shp boundary polygon for each individual file
(using the merge option will only create one big polygon).  I can then
use "vector/data management tools/merge the shapefile to one" to make
one file.
The problem is I need a field (the file names) for each polygon. Is
there an field expression for this?
This field is not created by lasboundary or my "merge the shapefile to
one".  Perhaps I can use the "Advanced Python field calculator" in batch
mode in the processing plugin but I don't know how to return the files
names. Can someone help or give my and idea of how to proceed?
Thanks in advance
Nicolas
