[Qgis-user] Any working GRASS in QGIS available?
Alex Mandel
tech_dev at wildintellect.com
Sun Aug 2 13:44:58 PDT 2015
After some brief testing, my OSGeoLive 8.5 VM with QGIS 2.6 and
Processing 2.9.3, GRASS 7 works.
My QGIS 2.8, GRASS 6/7, Processing 2.10.1 does not.
Both are Ubuntu 14.04 based.
I'm not sure if this is a bug in Processing, or in packaging. I recall
in OSGeoLive 8.5 that we had custom packages with a patch. Note, you can
get those versions for your Ubuntu system from
https://launchpad.net/~osgeolive/+archive/ubuntu/release-8.5
We freeze a copy of the working versions in our own ppa for long term
history.
Thanks,
Alex
On 2015-08-02 03:32, Bernd Vogelgesang wrote:
> Hi Alex,
> Am 02.08.2015, 01:22 Uhr, schrieb Alex Mandel <tech_dev at wildintellect.com>:
>> It's not a Windows/Ubuntu/Mac/OS thing, it's a QGIS + GRASS version
>> change thing.
>> Please indicate which version of QGIS and GRASS you are trying to get
>> working.
> Actually I do not mind any more what version I would like to get
> working. I would have preferred the 2.8-LTR branch with no-matter-what
> GRASS version.
> I just would like to be able to finish my project, and there is
> unfortunately no alternative to the GRASS algos in my model.
>> QGIS 2.6 and older works with GRASS 6, 2.8+ sometimes is built to work
>> with GRASS 7 (though possibly also with GRASS 6).
> Mhm, reverting to 2.6 ... Lets see if this still possible at all ...
>> If you want a guaranteed working setup ASAP download a copy of OSGeo
>> Live Virtual Machine, we made sure that it works in that.
>> http://live.osgeo.org
> Will give it a try. Download will take another 1.5 hours ...
> So does that mean that even your do not have a working GRASS in a recent
> QGIS by "normal" means but the osgeo VM?
>> Thanks,
>> Alex
> Cheers
> Bernd
>> On 2015-08-01 14:41, Bernd Vogelgesang wrote:
>>> Hi guys,
>>> is it just bad karma, that I seem not to able to get a working GRASS in
>>> QGIS? Or did I miss the big advertisement "GRASS out of order"
>>> somewhere.
>>> For nearly 2 weeks, I tried to get things to work in Ubuntu/Mint, and
>>> tried every possible/impossible repository, but always GRASS has missing
>>> dependencies, the forms open in Processing, but the algos don't run
>>> through, or the functions are working in Processing, but failing in the
>>> modeller.
>>> As I really got to finish a model in the Modeller including some GRASS
>>> algos, I finally turned on my VM with Windows ...
>>> but what the heck? Same s...t there!
>>> I really wonder why there aren't many post about trouble with GRASS on
>>> this list or at stackexchange, normally this would explode when things
>>> like these happen.
>>> So am I really the one with the bad karma, do you all other simply not
>>> use GRASS in processing as much as I do, or do you all simply have
>>> working installs, so there is not problem?
>>> Please, at least one: Do you have an install under Ubuntu or Windows,
>>> where GRASS algos are functional in the Modeler ? If yes, which
>>> version/what did you do?
>>> ... Soon, I will go and find me a rope ...
>>> Bernd
