[Qgis-user] QGIS and ECW files
Simon Cropper
contact at simonchristophercropper.com
Sun Aug 2 22:46:30 PDT 2015
Hello,
Sorry for binging up an old chestnut but I am not able to get ECW
support on QGIS.
Here is a dump of my QGIS configuration..
QGIS version 2.8.3-Wien
QGIS code revision exported
Compiled against Qt 4.8.6
Running against Qt 4.8.6
Compiled against GDAL/OGR 1.11.2
Running against GDAL/OGR 1.11.2
Compiled against GEOS 3.4.2-CAPI-1.8.2
Running against GEOS 3.4.2-CAPI-1.8.2 r3921
PostgreSQL Client Version 9.3.4
SpatiaLite Version 4.1.1
QWT Version 5.2.3
PROJ.4 Version 480
QScintilla2 Version 2.8.1
REPO: deb http://qgis.org/ubuntugis-ltr trusty main
What I have tried...
http://muhammadbaihaqi-martin92.blogspot.com.au/2014/05/install-ecw-support-qgis-220-valmiera.html
Successfully implemented all but the 'sudo gdal-ecw-build', which baulks
because I don't have gdal-config installed. Despite every attempt the
system is preventing me from installing gdal-config due to dependency
misalignments.
Command implemented -- sudo apt-get install libgdal-dev
Error -- libgdal-dev : Depends: libgdal1h (= 1.10.1+dfsg-5ubuntu1) but
1.11.2+dfsg-1~exp2~trusty is to be installed
Does anyone have any idea how I should/could resolve this problem?
Cheers Simon
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150803/465c1390/attachment.html>
