[Qgis-user] How qgis calculate the min/max of floating point	raster
    Nicolas Cadieux
    nicolas.cadieux at archeotec.ca
    Thu Aug  6 07:32:25 PDT 2015
That value is only good the first time you open the file. Then, a XML is created and that statistic changes with the display value of the raster.  Don't know why.  The best way is to use gdal info with the processing tools.
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112  Fax: 514.381.4995
www.archeotec.ca
On Aug 5, 2015 5:46 AM, "Andrea Peri [via OSGeo.org]" <ml-node+s1560n5218585h96 at n6.nabble.com> wrote:
when I add a flot raster to qgis canvas, and see the starting property settings,
I see the qgis has populated the min/max for ever band.
But this vales are not corresponding with the results from
gdalinfo raster.tif
So I guess they are calculated with some algorithm.
Is this algorithm knowed ?
Thx,
Andrea Peri
qwerty àèìòù
Qgis-user mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/qgis-user
		If you reply to this email, your message will be added to the discussion below:
		http://osgeo-org.1560.x6.nabble.com/How-qgis-calculate-the-min-max-of-floating-point-raster-tp5218585.html
		To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
		To unsubscribe from Quantum GIS - User, click here .
		NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/How-qgis-calculate-the-min-max-of-floating-point-raster-tp5218585p5218798.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150806/2aa01abc/attachment.html>
