[Qgis-user] Georeferencing Vector Files
    Richard McDonnell
    richard.mcdonnell at opw.ie
    Fri Aug  7 01:07:02 PDT 2015
There is one sure way to do this, Use your CAD Package to align the
property survey to the correct CRS, using two common points.
What CAD Package are you using, if you have AutoCAD, then you can use
the align command to preform this, I assume that other packages have
similar commands!
There are vector align plugin's available, but I find the above method
simplest, There is a CAD plugin being proposed to help with this process
in the future, but it is unfortunately not yet available.
I hope this helps, If I can be of any further help, let me know.
Regards,
Richard.
On 06/08/2015 19:08, Springfield Harrison wrote:
> Hello All,
> Is there a tool/plugin for georeferencing vector files to an existing
> projected layer?
> I'm intending to bring in property survey drawings that have only
> local coordinates but projected coordinates (UTM) are available for
> some corners.
> Thank you . . . .
> Cheers . . . . .   Springfield Harrison
> Samsung Tab 4
> Qgis-user mailing list
OPW - Ag féachaint don am atá le teacht - Ag caomhnú ón am atá thart
OPW - Looking to the future - Caring for the past
Email Disclaimer: http://www.opw.ie/en/disclaimer/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150807/b8c88057/attachment.html>
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150807/b8c88057/attachment.vcf>
