[Qgis-user] Georeferencing Vector Files
Springfield Harrison
stellargps at gmail.com
Fri Aug 7 12:02:52 PDT 2015
Thanks Andre, I've loaded these Plugins, will
try them. However, one is missing dependencies so may try the other.
Thanks, cheers . . . . Spring Harrison
At 06-08-2015 20:46 Thursday, Andre Joost wrote:
>Am 06.08.2015 um 20:08 schrieb Springfield Harrison:
>>Hello All,
>>Is there a tool/plugin for georeferencing vector files to an existing
>>projected layer?
>The plugins Vector Bender and vectorgeoref
>should do what you want. You have to enable experimental plugins to see them.
>And maybe the Affine Transformations plugin also works for you.
>HTH,
>André Joost
>_______________________________________________
>Qgis-user mailing list
>Qgis-user at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/qgis-user
