[Qgis-user] Georeferencing Vector Files
Alex Mandel
tech_dev at wildintellect.com
Sat Aug 8 23:20:22 PDT 2015
Save the whole map, it's on the main File menu, it just saves the
current canvas.
If you already have a list of gcps you can skip that step
Example
http://gis.stackexchange.com/questions/107298/process-to-georeference-corners-of-vector-file
Enjoy,
Alex
On 08/08/2015 07:26 PM, Springfield Harrison wrote:
> Hello Alex,
> Further to my last, for Vector Save As, I couldn't find any
> option to save it as a raster file. Is there some other place to look?
> Thanks again, Cheers . . . . . . . . Spring Harrison
> At 08-08-2015 12:07 Saturday, Alex Mandel wrote:
>> On 08/06/2015 11:08 AM, Springfield Harrison wrote:
>> > Hello All,
>> > Is there a tool/plugin for georeferencing vector files to an existing
>> > projected layer?
>> > I'm intending to bring in property survey drawings that have only local
>> > coordinates but projected coordinates (UTM) are available for some
>> corners.
>> > Thank you . . . .
>> > Cheers . . . . . Springfield Harrison
>> > Samsung Tab 4
>> My trick, is convert the vector an image in QGIS (Save Image)
>> Georeference the image, saving the control point list out to a file.
>> You can then use these control points (gcps) with ogr2ogr to transform
>> the original vector.
>> -Alex
> Qgis-user mailing list
