[Qgis-user] Georeferencing Vector Files
Alex Mandel
tech_dev at wildintellect.com
Sun Aug 9 10:52:18 PDT 2015
ogr2ogr is a command line tool, Terminal/Shell on Mac/Linux, OSGeo4w
shell on Windows.
Supposedly the Vector Georef plugin wraps this functionality into QGIS.
-Alex
On 08/09/2015 12:08 AM, Springfield Harrison wrote:
> Right, but where is org2org? I've looked in many menu items, help, etc.
> to no avail.
> Sorry to be a bit thick but how is it accessed?
> Also, GRASS has v.transform and v.rectify but starting a new GRASS
> mapset fails with no reason given.
> Great tools but why are they so hard to access?
> Thanks, cheers . . . . Spring Harrison
> At 08-08-2015 23:20 Saturday, Alex Mandel wrote:
>> Save the whole map, it's on the main File menu, it just saves the
>> current canvas.
>> If you already have a list of gcps you can skip that step
>> Example
>> http://gis.stackexchange.com/questions/107298/process-to-georeference-corners-of-vector-file
>> Enjoy,
>> Alex
>> On 08/08/2015 07:26 PM, Springfield Harrison wrote:
>> > Hello Alex,
>> > Further to my last, for Vector Save As, I couldn't find any
>> > option to save it as a raster file. Is there some other place to look?
>> > Thanks again, Cheers . . . . . . . . Spring Harrison
>> > At 08-08-2015 12:07 Saturday, Alex Mandel wrote:
>> >> On 08/06/2015 11:08 AM, Springfield Harrison wrote:
>> >> > Hello All,
>> >> > Is there a tool/plugin for georeferencing vector files to an
>> existing
>> >> > projected layer?
>> >> > I'm intending to bring in property survey drawings that have only
>> local
>> >> > coordinates but projected coordinates (UTM) are available for some
>> >> corners.
>> >> > Thank you . . . .
>> >> > Cheers . . . . . Springfield Harrison
>> >> > Samsung Tab 4
>> >> My trick, is convert the vector an image in QGIS (Save Image)
>> >> Georeference the image, saving the control point list out to a file.
>> >> You can then use these control points (gcps) with ogr2ogr to transform
>> >> the original vector.
>> >> -Alex
>> > _______________________________________________
>> > Qgis-user mailing list
>> > Qgis-user at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/qgis-user
