[Qgis-user] QGIS & Spatialite: problem with renewed views
Matthias Kuhn
matthias at opengis.ch
Mon Aug 10 07:01:26 PDT 2015
Hi xof,
Maybe this is the same issue like this: https://hub.qgis.org/issues/8923?
Basically, check if this SQL statements helps to "refresh" your view's
fields:
https://hub.qgis.org/issues/8923#note-5
Cheers,
Matthias
On 08/10/2015 03:17 PM, X Of wrote:
> Hi Andrea
> The problem described is independent of projects or restarting QGIS.
> The problem is always present already in the window for adding a new
> spatialite-layer (ctrl-shift-L). There you can get a list of available
> fields, when pushing the button for filtering a table ("Set Filter"
> Button)... And this list of available fields is sort of a preview of
> what you're going to get when adding the table as a layer to your
> qgis-project.
> So is it possible that this "add-layer-manager" might be the source of
> the problem, maybe?
> Do you think it's worth filing a bug?
> Thank you for your help
> xof
> 2015-08-09 17:51 GMT+02:00 Andrea Peri <aperi2007 at gmail.com
> <mailto:aperi2007 at gmail.com>>:
> Hi xof,
> you are using a gis project ?
> I guess more probably the explanation could be the qgis that save the
> fields name and alias in the project.
> If you try to start a new project this happened however ?
> A.
> 2015-08-09 17:41 GMT+02:00 X Of <xof.biz at gmail.com
> <mailto:xof.biz at gmail.com>>:
> > Dear List
> > In spatialite, if I renew a view (drop a view and recreate it
> under the same
> > name but with different content/fields), QGIS somehow is not
> adapting to
> > this new situation. I am not able to re-import the new view as a
> layer to
> > QGIS (well, I'm able to re-import, but QGIS only shows the
> fields that have
> > been present in the previous version of the view, that got dropped).
> > In the db-manager everything is looking good - I can "manually"
> query the
> > renewed view just fine.
> > I've tried to also delete the view from the
> views_geometry_columns-table and
> > re-insert it there - QGIS still doesn't recognize the new view.
> > My only workaround so far ist to create the new view under a
> slightly
> > different name each time (testview2, testview3, testview4...).
> > Any help on this topic is highly appreciated..
> > Thank you!
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> Andrea Peri
> qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150810/7e5494d2/attachment.html>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150810/7e5494d2/attachment.sig>
