[Qgis-user] Georeferencing Vector Files
    Nathan Woodrow
    madmanwoo at gmail.com
    Mon Aug 10 23:07:44 PDT 2015
>> I would just suggest that this advanced/simple option be made more
prominent, probably at the top.  I thought it was just a secondary title
and never even saw the drop-down arrow.  Make it a radio button or
something obvious.
Yeah there is on going talk about what we can do here.  Maybe even killing
the simplified interface, not sure yet.
The progressing toolbox should do what you need and you won't have to worry
about map sets and all that.
Regards,
Nathan
On Tue, Aug 11, 2015 at 4:01 PM, Springfield Harrison <stellargps at gmail.com>
wrote:
> Hi Nathan,
>         Now we are getting somewhere!  I would just suggest that this
> advanced/simple option be made more prominent, probably at the top.  I
> thought it was just a secondary title and never even saw the drop-down
> arrow.  Make it a radio button or something obvious.
>         And I think I see what Alex Mandel was referring to about the
> raster image.  By pretending to Georeference the raster image, one will
> build a GCP file automatically.  At least, I think that was the intent.
>         Anyway, thanks for this, I may actually get somewhere now.  This
> certainly beats jumping through all the hoops to set up a GRASS session.
>                           Thanks again, Cheers . . . . . . . . Spring
> Harrison
> At 10-08-2015 22:40 Monday, Nathan Woodrow wrote:
> At the bottom of that dock there is a interface selection tool. Change it
> to advanced interface.
> [image: Inline image 1]
> Note: There is ongoing discussion on the dev mailing list on how we can
> improve this.
> Regards,
> NathanÂ
> On Tue, Aug 11, 2015 at 3:17 PM, Springfield Harrison <
> stellargps at gmail.com> wrote:
> Hey Yourself,
> Â Â Â Â Â Â Â Â Very interesting, this is what I get, bugger all:
> [image: Emacs!]
>         So what accounts for the difference? Some installation
> quirk no doubt. I did select GRASS as an installation option. In 2.8.3 it
> was listed under plug-ins, but under 2.10.1 is no longer there. But it was
> installed as a standalone.
> Â Â Â Â Â Â Â Â Consistency does not seem to be a strong point here.
> Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â I do appreciate the help however, I'm sure
> there is an answer somewhere, Cheers . . . . . . . . Spring Harrison
> At 10-08-2015 22:10 Monday, Nathan Woodrow wrote:
> Hey,
> Did you do a search in the top part of the dock:
> Regards,
> Nathan
> On Tue, Aug 11, 2015 at 3:06 PM, Springfield Harrison <
> stellargps at gmail.com> wrote: Hello Thomas,
> Â Â Â Â I have hunted high and low in the Processing Toolbox and
> cannot find any place there to enter command line instructions. They all
> seem to be pre-coded tools, nothing with a command line. Should I be
> looking somewhere else?
> Â Â Â Â Â Â Â Â Thank you again, Cheers . . . . . . . . Spring
> Harrison
> At 10-08-2015 03:27 Monday, Thomas Colley wrote: Hi
> I did this recently using the GRASS command v.transform.pointsfile from
> the Processing Toolbox in QGIS. No need to actually go into GRASS and
> create mapsets.
> This worked really well for me for unreferenced DXFs. If you need any more
> info let me know.
> Cheers
> Tom
> -----Original Message----- From: qgis-user-bounces at lists.osgeo.org [
> <qgis-user-bounces at lists.osgeo.org>
> mailto:qgis-user-bounces at lists.osgeo.org
> <qgis-user-bounces at lists.osgeo.org>] On Behalf Of Springfield Harrison Sent:
> 09 August 2015 19:51 To: tech at wildintellect.com; qgis-user Subject: Re:
> Ok, thanks. I'm installing QGIS on W7 yet again, trying to achieve better
> functionality. That is a challenge in itself, prone to wrong turns.
> Hopefully the VectorGeoref will then work.
> This whole install process is a real piece of work . . . . .
>         Thanks again, cheers . . . . Spring Harrison
> At 09-08-2015 10:52 Sunday, Alex Mandel wrote: >ogr2ogr is a command line
> tool, Terminal/Shell on Mac/Linux, OSGeo4w >shell on Windows. > >Supposedly
> the Vector Georef plugin wraps this functionality into QGIS. > >-Alex > >On
> 08/09/2015 12:08 AM, Springfield Harrison wrote: > > Right, but where is
> org2org? I've looked in many menu items, help, etc. > > to no avail. > > >
> > Sorry to be a bit thick but how is it accessed? > > > > Also, GRASS has
> v.transform and v.rectify but starting a new GRASS > > mapset fails with
> no reason given. > > > > Great tools but why are they so hard to access? >
> > > >Â Â Â Â Thanks, cheers . . . . Spring Harrison > > > > > > > >
> At 08-08-2015 23:20 Saturday, Alex Mandel wrote: > >> Save the whole map,
> it's on the main File menu, it just saves the > >> current canvas. > >> >
> >> If you already have a list of gcps you can skip that step > >> > >>
> Example > >> >
> http://gis.stackexchange.com/questions/107298/process-to-georeference- >
> corners-of-vector-file > >> > >> > >> > >> Enjoy, > >> Alex > >> > >> On
> 08/08/2015 07:26 PM, Springfield Harrison wrote: > >> > Hello Alex, > >>
> > > >> >Â Â Â Further to my last, for Vector Save As, I couldn't find
> any > >> > option to save it as a raster file. Is there some other place
> to look? > >> > > >> >Â Â Â Â Â Â Â Thanks again, Cheers . . . . .
> . . . Spring
> > >> > Harrison > >> > > >> > > >> > > >> > > >> > At 08-08-2015 12:07
> Saturday, Alex Mandel wrote: > >> >> On 08/06/2015 11:08 AM, Springfield
> Harrison wrote: > >> >> > Hello All, > >> >> > > >> >> > Is there a
> tool/plugin for georeferencing vector files to an > >> existing > >> >> >
> projected layer? > >> >> > > >> >> > I'm intending to bring in property
> survey drawings that have > >> >> > only > >> local > >> >> > coordinates
> but projected coordinates (UTM) are available for > >> >> > some > >> >>
> corners. > >> >> > > >> >> > Thank you . . . . > >> >> > > >> >> > Cheers
> . . . . . Springfield Harrison Samsung Tab 4 > >> >> > > >> >> > > >> >> >
> >> >> My trick, is convert the vector an image in QGIS (Save Image) > >>
> >> Georeference the image, saving the control point list out to a file. >
> >> >> You can then use these control points (gcps) with ogr2ogr to
> transform > >> >> the original vector. > >> >> > >> >> -Alex > >> > > >>
> > _______________________________________________ > >> > Qgis-user
> mailing list > >> > Qgis-user at lists.osgeo.org > >> >
> http://lists.osgeo.org/mailman/listinfo/qgis-user > >
> _______________________________________________ Qgis-user mailing list
> Content-Type: image/png; name="image.png"
> Content-Disposition: inline; filename="image.png"
> Content-ID: <ii_14f1b2a0fcba84e3>
> X-Attachment-Id: ii_14f1b2a0fcba84e3
> Content-Type: image/png; name="1eab515.png"; x-mac-type=504E4766;
> x-mac-creator=6D646F73
> Content-Disposition: inline; filename="1eab515.png"
> Content-ID: <7.1.0.9.0.20150810221120.071c64e0 at gmail.com.2>
> X-Attachment-Id: ffc3864d6493c0d3_0.2
> Content-Type: image/jpeg; name="1eab4f6.jpg"; x-mac-type=4A504547;
> x-mac-creator=4A565752
> Content-Disposition: inline; filename="1eab4f6.jpg"
> Content-ID: <7.1.0.9.0.20150810221120.071c64e0 at gmail.com.1>
> X-Attachment-Id: ffc3864d6493c0d3_0.1
> Content-ID: <ii_14f1b3308fc4110d>
> X-Attachment-Id: ii_14f1b3308fc4110d
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150811/baf922c1/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150811/baf922c1/attachment.png>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150811/baf922c1/attachment.jpg>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150811/baf922c1/attachment-0001.png>
