[Qgis-user] Georeferencing Vector Files
Anita Graser anitagraser at gmx.at
Mon Aug 10 23:23:49 PDT 2015
Most likely the algorithm is hidden by the simplified interface. Change to
advanced using the drop down in the bottom of the toolbox.
And yes, we are already discussing if this interface option makes sense.
Best wishes
Anita
Hey Yourself,
        Very interesting, this is what I get, bugger all:
[image: Emacs!]
        So what accounts for the difference?  Some installation quirk no
doubt.  I did select GRASS as an installation option.  In 2.8.3 it was
listed under plug-ins, but under 2.10.1 is no longer there.  But it was
installed as a standalone.
         Consistency does not seem to be a strong point here.
                 I do appreciate the help however, I'm sure there is an
answer somewhere, Cheers . . . . . . . . Spring Harrison
At 10-08-2015 22:10 Monday, Nathan Woodrow wrote:
Hey,
Did you do a search in the top part of the dock:
[image: Inline image 1]
Regards,
Nathan
On Tue, Aug 11, 2015 at 3:06 PM, Springfield Harrison <stellargps at gmail.com>
wrote:
Hello Thomas,
    I have hunted high and low in the Processing Toolbox and cannot
find any place there to enter command line instructions. They all seem to
be pre-coded tools, nothing with a command line. Should I be looking
somewhere else?
        Thank you again, Cheers . . . . . . . . Spring Harrison
At 10-08-2015 03:27 Monday, Thomas Colley wrote:
Hi
I did this recently using the GRASS command v.transform.pointsfile from the
Processing Toolbox in QGIS. No need to actually go into GRASS and create
mapsets.
This worked really well for me for unreferenced DXFs. If you need any more
info let me know.
Cheers
Tom
-----Original Message-----
mailto:qgis-user-bounces at lists.osgeo.org <qgis-user-bounces at lists.osgeo.org>]
On Behalf Of Springfield Harrison
Sent: 09 August 2015 19:51
To: tech at wildintellect.com; qgis-user
Subject: Re: [Qgis-user] Georeferencing Vector Files
Ok, thanks. I'm installing QGIS on W7 yet again, trying to achieve better
functionality. That is a challenge in itself, prone to wrong turns.
Hopefully the VectorGeoref will then work.
This whole install process is a real piece of work . . . . .
        Thanks again, cheers . . . . Spring Harrison
At 09-08-2015 10:52 Sunday, Alex Mandel wrote:
>ogr2ogr is a command line tool, Terminal/Shell on Mac/Linux, OSGeo4w
>shell on Windows.
>Supposedly the Vector Georef plugin wraps this functionality into QGIS.
>-Alex
>On 08/09/2015 12:08 AM, Springfield Harrison wrote:
> > Right, but where is org2org? I've looked in many menu items, help, etc.
> > to no avail.
> > Sorry to be a bit thick but how is it accessed?
> > Also, GRASS has v.transform and v.rectify but starting a new GRASS
> > mapset fails with no reason given.
> > Great tools but why are they so hard to access?
> >Â Â Â Â Thanks, cheers . . . . Spring Harrison
> > At 08-08-2015 23:20 Saturday, Alex Mandel wrote:
> >> Save the whole map, it's on the main File menu, it just saves the
> >> current canvas.
> >> If you already have a list of gcps you can skip that step
> >> Example
> http://gis.stackexchange.com/questions/107298/process-to-georeference-
> corners-of-vector-file
> >> Enjoy,
> >> Alex
> >> On 08/08/2015 07:26 PM, Springfield Harrison wrote:
> >> > Hello Alex,
> >> >Â Â Â Further to my last, for Vector Save As, I couldn't find any
> >> > option to save it as a raster file. Is there some other place to
look?
> >> >Â Â Â Â Â Â Â Thanks again, Cheers . . . . . . . . Spring
> >> > Harrison
> >> > At 08-08-2015 12:07 Saturday, Alex Mandel wrote:
> >> >> On 08/06/2015 11:08 AM, Springfield Harrison wrote:
> >> >> > Hello All,
> >> >> > Is there a tool/plugin for georeferencing vector files to an
> >> existing
> >> >> > projected layer?
> >> >> > I'm intending to bring in property survey drawings that have
> >> >> > only
> >> local
> >> >> > coordinates but projected coordinates (UTM) are available for
> >> >> > some
> >> >> corners.
> >> >> > Thank you . . . .
> >> >> > Cheers . . . . . Springfield Harrison Samsung Tab 4
> >> >> My trick, is convert the vector an image in QGIS (Save Image)
> >> >> Georeference the image, saving the control point list out to a file.
> >> >> You can then use these control points (gcps) with ogr2ogr to
transform
> >> >> the original vector.
> >> >> -Alex
> >> > _______________________________________________
> >> > Qgis-user mailing list
> >> > Qgis-user at lists.osgeo.org
> >> > http://lists.osgeo.org/mailman/listinfo/qgis-user
Content-Type: image/png; name="image.png"
Content-Disposition: inline; filename="image.png"
Content-ID: <ii_14f1b2a0fcba84e3>
X-Attachment-Id: ii_14f1b2a0fcba84e3
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150811/58cb804e/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150811/58cb804e/attachment.png>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150811/58cb804e/attachment.jpg>
