[Qgis-user] Conversion from World to Geo coordinates
Tudorache, Marian
Marian.Tudorache at navcanada.ca
Tue Aug 11 13:39:01 PDT 2015
Hi everyone,
I currently have some GIS data using the world format x and y where those were obtained by approximate the Earth with a modified GRS80 datum where the Semi-major axis = Semi-minor axis = 6381711.641389.
I would like to know if there is a plugin in QGIS which can convert automatically back to lat and long of any standard or custom datum.
Thank you,
Marian
This electronic message, as well as any transmitted files included in the electronic message, may contain privileged or confidential information and is intended solely for the use of the individual(s) or entity to which it is addressed. If you have received this electronic message in error please notify the sender immediately and delete the electronic message. Any unauthorized copying, disclosure or distribution of the electronic message is strictly forbidden. NAV CANADA accepts no liability for any damage caused by any virus and/or other malicious code transmitted by this electronic communication.
Le présent message électronique et tout fichier qui peut y être joint peuvent contenir des renseignements privilégiés ou confidentiels destinés à l’usage exclusif des personnes ou des organismes à qui ils s’adressent. Si vous avez reçu ce message électronique par erreur, veuillez en informer l’expéditeur immédiatement et supprimez le. Toute reproduction, divulgation ou distribution du présent message électronique est strictement interdite. NAV CANADA n’assume aucune responsabilité en cas de dommage causé par tout virus ou autre programme malveillant transmis par ce message électronique.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150811/21bc3ebb/attachment.html>
