[Qgis-user] QGis server project files stored in DB?
James Keener
jim at jimkeener.com
Wed Aug 12 06:29:35 PDT 2015
I was also looking for this a bit back and never found a solution. I ended
up using other software, unfortunately.
As for being less flexible, it is exactly as flexible as a qgs file would
be, it's just that they could be manipulated and created more easily. I
would love to see the parts of the file broke out in the database and not
just using a single text blob, though.
Also, setting up identical-enough is fairly trivial, especially if most of
the layers are already coming from a database, or known cache of shapefiles.
Jim
On Wed, Aug 12, 2015 at 9:13 AM, Andrea Peri <aperi2007 at gmail.com> wrote:
> I don't guess is more flexible.
> Infact usually the teting environment is never exactly exals to the
> publish environmnet.
> A file allw to open and correct the paths from develop and publish
> environment.
> Also the svg symbols could be not exactly with the same path from
> develop and publish environment.
> So having a same project in a db is more complex becasue need to have
> two environment exactly the same.
> And this is not possible.
> I guess the db storing for project could be more flexible only if the
> paths to the layers and relative paths of svg was not stored in the
> project file but instead in other files.
> My 2ct.
> A.
> 2015-08-12 15:06 GMT+02:00 lars lingner <gislars+list at gmail.com>:
> > Hello,
> > I'm looking for a solution for storing QGis project files (qgs) in a
> > PostgreSQL database. Storing the files in a table isn't actually the
> > problem, but getting it out and feeding it to QGis server.
> > Did anyone had this need already? Would this be a good idea?
> > In my use case the project files are generated, based on a default
> > project file. Having the file in the DB would give more flexibility.
> > Since saving the style in DB is already supported by QGis, I'm just
> > curious of opinions of other users or developers.
> > Thanks in advance for any feedback
> > Lars
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> Andrea Peri
> qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150812/60c78967/attachment.html>
