[Qgis-user] Base directory for images for QGIS-server
Tom Palan
thomas at palan.at
Fri Aug 14 04:34:14 PDT 2015
hi,
I successfully setup the QGIS-server & QGIS-web-client, and I am now trying to get printouts working. Everything works so far, except the path where QGIS-server is looking for images files is /usr/lib/cgi-bin (the work directory).
I do not want to specify absolute paths in the print composer, and writing to the /usr/lib/cgi-bin directory is also not a good solution. Is there an environment variable I can set that is parsed by QGIS-server?
thanks a lot
Tom Palan
palan3 IT solutions OG
Grillenbergstr. 4
A-4407 Dietach
Tel.: +43 (0) 680 3280940
Fax.: +43 (0) 7252 38508 80
