[Qgis-user] Control Layers using Atlas
Alexandre Neto
senhor.neto at gmail.com
Fri Aug 14 16:34:31 PDT 2015
It would. I also thought that the same could be done to layer groups.
Still, I would prefer to see data-defined properties for locking layer
(presets) in map items in the map composer. It would be much easier to pick
a few layers, create a few presets, and them "iterare" them in atlas.
Em sex, 14 de ago de 2015 às 23:27, Nyall Dawson <nyall.dawson at gmail.com>
escreveu:
> On 15 August 2015 at 00:34, Alexandre Neto <senhor.neto at gmail.com> wrote:
> > Hi,
> > I made a few tests and, it works well for vector layer. All you need is
> the
> > right coverage layer, a top rule in all layers that you need to controlo.
> > Like you said, Yhis does not work for raster layer, neither it work for
> > vector renderers like ppint displacement or heatmap.
> > Also using legend filter, one can also adapt the maps legend.
> What about if there was a data-defined "layer visibility" control
> available for vector and raster layers? Would that solve the problem?
> Nyall
> > Em sex, 14 de ago de 2015 às 12:10, Thomas Colley
> > <it087 at neath-porttalbot.gov.uk> escreveu:
> >> Hi Alexandre
> >> I think the rule based symbology would work but I’m trying to print a
> >> series of raster layers so unfortunately that’s not an option this time.
> >> Thanks for your help, I’ll keep looking into it and let you know if I
> find
> >> anything.
> >> Tom
> >> From: Alexandre Neto [mailto:senhor.neto at gmail.com]
> >> Sent: 14 August 2015 11:59
> >> To: Thomas Colley; qgis-user at lists.osgeo.org
> >> Subject: Re: [Qgis-user] Control Layers using Atlas
> >> Hello Thomas,
> >> I had that need aswell. If data defined properties were made possible in
> >> the map composer lock preset option, that would be something direct to
> do.
> >> Just occured that one might somehow achieve that by transforming each
> >> layer's symbology into a rule-based symbology, and set a general rule to
> >> render the feature only if there is a match between a atlas coverage
> field.
> >> Dont' know if that would work, but it worth a try.
> >> Let me know if you could do it.
> >> Alexandre Neto
> >> Em sex, 14 de ago de 2015 às 11:44, Thomas Colley
> >> Hi
> >> Is it possible to use Atlas to print out a number of maps each showing a
> >> different layer instead of a different area of interest?
> >> I'm thinking the atlas layer would have the same area of interest
> polygon
> >> duplicated with an attribute that holds the layer name(s) to be
> displayed.
> >> I'm sure I have seen this discussed/explained somewhere before but now I
> >> can't find anything on it, maybe I've just made it up!
> >> Thanks
> >> Tom
> >> _______________________________________________
> >> Qgis-user mailing list
> >> Qgis-user at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150814/e36b3797/attachment.html>
