[Qgis-user] Dimension feature using QGIS Wien
Springfield Harrison stellargps at gmail.com
Tue Aug 18 07:21:57 PDT 2015
I had the same problem . . .
"I am not able to insert “selected two vertex points” (first icon of
plugin);"
Cheers . . . . .   Spring Harrison
Samsung Tab 4
On Aug 18, 2015 12:40 AM, "Franco Cazzola" <F.Cazzola at amga.it> wrote:
> Hi to everyone
> I am looking forward to the problem to add *dimension feature* to Qgis
> “Wien”
> I found two possibilities:
> -       Add dimension to a shape file using *ArcMap dimension feature*
> and add layer to Qgis
> (in Qgis I see only the boundary of the feature “like a buffer around the
> lines”, and the label), I can’t use it in this way
> or
> -       Using dimension plugin in Qgis;
> plugin); are there any setting or prerequisites to use it ? I tried also
> creating a SpatiaLite database …. resultles
> Thanks for all contributions
> *Franco Cazzola*
> *Telefono Ufficio      :  0331884877 *
> *Telefono Cellulare  :  3408375775*
> *Mail                          :  F.Cazzola at amga.it <F.Cazzola at amga.it>*
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150818/e22c13b2/attachment.html>
