[Qgis-user] 2.10 Build error on OSX
Radim Blazek
radim.blazek at gmail.com
Tue Aug 18 08:15:41 PDT 2015
Regarding the next issue reported here:
https://trac.macports.org/ticket/48563, I don't know what does it mean
"Marking ... as broken" on OS X. If it means that there are missing
shared libs, it could be that QGIS was compiled with GRASS 6 support,
but GRASS 6 is not installed.
Radim
On Tue, Aug 18, 2015 at 5:06 PM, Radim Blazek <radim.blazek at gmail.com> wrote:
> On Tue, Aug 18, 2015 at 4:09 PM, Pieter du Plooy <pjduplooy at zpanelcp.com> wrote:
>> Hi guys
>> I get the following error while building 2.10 on OSX with Homebrew:
>> /tmp/qgis-21020150818-13516-6fgnoh/QGIS-final-2_10_1/src/providers/grass/qgsgrassdatafile.cpp:76:7:
>> error: unknown type name 'fd_set'
>> fd_set readFds;
> The problem is that #ifdef using Q_OS_UNIX is before <QtGlobal> header
> file where it is defined was included. Larry Shaffer fixed that in
> master https://github.com/qgis/QGIS/commit/d722f5bd4b8. Apply that
> patch or add #include <QtGlobal> at top of the file.
> It seems that sys/select.h gets always included in other way on Linux.
> Radim
