[Qgis-user] QGIS 2.10.1 adding PostGIS Views
James Keener
jim at jimkeener.com
Mon Aug 31 12:05:05 PDT 2015
I don't mind the behavior as much as it's entirely unclear, especially
when the window is small and you have to scroll to see the drop down,
what is the problem.
There should be an error message (or even an error/warning icon with the
tool tip saying there is on PK), along with possible remedies presented
to the user.
Jim
On 08/31/2015 03:00 PM, Luca Lanteri wrote:
> Hi,
> I noticed that this new behavior has been backported to 2.8.3.
> I think this behavior should be considered a regression because now it's
> very uncomfortable to load views, specially when I have to load many
> views. I also noticed that lot of users are confused, because they
> thinks that views doesn't work. I think the old behavior was better
> because it allowed both to choose a custom gid and to load view faster.
> Currently we decide to remain with 2.8.2.
> What about reconsidering to return to the old behavior ?
> Thanks
> Luca
> 2015-08-06 20:58 GMT+02:00 Jürgen E. <jef at norbit.de <mailto:jef at norbit.de>>:
> Hi Randal,
> On Thu, 06. Aug 2015 at 13:53:08 -0400, Randal Hale wrote:
> > In 2.8.x I can add the view and the Primary key is automatically displayed.
> No, you're supposed to select the primary key. In 2.8.x you also
> have to
> choose from all columns, but first one is preselected. If that
> happens to be
> the primary key, you're fine, but that's not always the case and hence
> newer versions force you to actually select it.
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel.
> +49-4931-918175-31 <tel:%2B49-4931-918175-31>
> Dipl.-Inf. (FH) Rheinstraße 13 Fax.
> +49-4931-918175-50 <tel:%2B49-4931-918175-50>
> Software Engineer D-26506 Norden
> http://www.norbit.de
> QGIS release manager (PSC) Germany IRC: jef on
> FreeNode
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
