[Qgis-user] Calculate Areas for Vector Overlays
yanoff at tularosa.net
Wed Feb 4 13:35:58 PST 2015
Is there an efficient way to calculate areas of polygons in one vector layer
(shapefile) that intersect polygons in another vector layer?
For example, overlaying a nature preserve shapefile onto a land ownership
shapefile, I want to know the summed areas (e.g., ha) of each preserve in
each ownership. For example, Preserve-1 is 10,000 ha private, 1000 ha
government, etc.
One way to do this is to intersect the two shapefiles (Vector >
Geoprocessing Tools > Intersect), which creates a new shapefile, and then
extract results from the new shapefile's attribute table. However, this is
time consuming.
There is a Tabulate Areas function in ArcGIS that performs a similar
function, where you can choose the fields to sum on (e.g., preserve name,
ownership), that performs an internal raster overlay and outputs a table.
But it is typically for rasters. Also, someone previously asked if a
similar function exists in QGIS, but so far there were no replies.
Thanks!
Steven Yanoff
View this message in context: http://osgeo-org.1560.x6.nabble.com/Calculate-Areas-for-Vector-Overlays-tp5185581.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
