[Qgis-user] node tool zoom problem
    Nathan Woodrow
    madmanwoo at gmail.com
    Wed Feb  4 14:28:52 PST 2015
Wannes,
You should check your snapping settings in Settings -> Snapping.  You might
have it set to map units which means as you zoom out it becomes smaller
because it's using real distance vs pixels which are constant.
- Nathan
On Wed Feb 04 2015 at 8:13:07 PM Wannes De Crop <Wannes.DeCrop at ugent.be>
wrote:
> Hi,
> It has been a while since I used QGIS so about 2 weeks ago I installed
> 2.6.1 (on Windows 7 Home Premium, 64 bits). For the last couple of
> days I've been working on a shapefile. Yesterday morning I try to
> continue, add feature works fine, but when I zoom in and try to adjust
> some nodes using the node tool I get this message "Node tool: could
> not snap to a segment on the current layer.". I frantically click
> around and notice that is does work when I'm more zoomed out (which is
> of course completely useless in this case). I've tried different
> settings, new projects and shapefiles and deleted and reinstalled QGIS
> 2.6.1, but no luck there. I still have an old version of QGIS (1.7.0)
> as well where the node tool works fine with the same settings. Any
> ideas?
> Cheers,
> Wannes
> Wannes De Crop
> Ghent University
> Department of Biology, Research Group Limnology
> K.L. Ledeganckstraat 35
> B - 9000 Ghent Belgium
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150204/9b9d3215/attachment.html>
