[Qgis-user] dxf2shp - keep property
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Thu Feb 5 03:51:47 PST 2015
I know you can export those properties in columns if you export from AutoCAD.
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112 Fax: 514.381.4995
Le 2015-02-05 02:49, "Torsten Lange-2 [via OSGeo.org] " <ml-node+s1560n5185641h32 at n6.nabble.com> a écrit :
Hi, Does anyone knows a workaround that keeps feature properties of a dxf-file? Specifically, I have isolines with a property "elevation" that is to keep for labeling purpose in the map. Dxf2shp plugin, as well as Grass v.in.dxf and Saga dxf modules seem not to provide this functionality. Thank you, Torsten
Qgis-user mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/qgis-user
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/dxf2shp-keep-property-tp5185641.html
To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
To unsubscribe from Quantum GIS - User, click here .
NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/dxf2shp-keep-property-tp5185641p5185704.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150205/3aa8e929/attachment.html>
