[Qgis-user] dxf2shp - keep property
Torsten Lange torsten.lange at mail.de
Thu Feb 5 11:01:58 PST 2015
If we had, I could probably use AutoCAD Map, but we don't have it, because geological surveys are not supposed to use engineering solutions ;)
Torsten
Am 05-Feb-2015 17:16:37 +0100 schrieb bob.basques at ci.stpaul.mn.us:
If you have AutoCAD Map, you can export with any of the feature properties included in the export as feature attributes.
Bobb
FROM: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] ON BEHALF OF Nicolas Cadieux
SENT: Thursday, February 05, 2015 5:52 AM
TO: qgis-user at lists.osgeo.org
SUBJECT: Re: [Qgis-user] dxf2shp - keep property
 I know you can export those properties in columns if you export from AutoCAD.
Nicolas Cadieux M.Sc.
 Les Entreprises Archotec inc.
 8548, rue Saint-Denis Montral H2P 2H2
 Tlphone: 514.381.5112 Fax: 514.381.4995
Le 2015-02-05 02:49, "Torsten Lange-2 [via OSGeo.org] "  a crit :
 Does anyone knows a workaround that keeps feature properties of a dxf-file?
 Specifically, I have isolines with a property "elevation" that is to keep for labeling purpose in the map. Dxf2shp plugin, as well as Grass v.in.dxf and Saga dxf modules seem not to provide this functionality.
 Thank you, Torsten
 Qgis-user mailing list
IF YOU REPLY TO THIS EMAIL, YOUR MESSAGE WILL BE ADDED TO THE DISCUSSION BELOW:
http://osgeo-org.1560.x6.nabble.com/dxf2shp-keep-property-tp5185641.html
To start a new topic under Quantum GIS - User, email [hidden email]
 To unsubscribe from Quantum GIS - User, click here.
NAML
View this message in context:  Re: dxf2shp - keep property
 Sent from the  Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150205/95f12801/attachment.html>
