[Qgis-user] Build raster cataloge from directory and subdirectories with only one type of files?
    Johan Nilsson
    joni8135 at gmail.com
    Thu Feb  5 13:20:17 PST 2015
Thanks Alex. Worked just fine.  great :)
2015-02-05 20:06 GMT+01:00 Alex Mandel <tech_dev at wildintellect.com>:
> On 02/05/2015 10:17 AM, Johan Nilsson wrote:
> > Using QGIS 2.6.1 on Ubuntu 14.04
> > It is possible to Build Virtual Raster and select directory but only take
> > one type of files, fore instance *.asc and not *.tif?
> > You may select file-types, but only if you select input files not input
> > directory  (and recurse subdirectories) under Menu:
> > Raster-->Miscellanous-->Build Virtual Raster (Catalog)
> >  When you check 'Choose input directory instead of files' input filetypes
> > get greyed out....
> > Are there another way to Build Raster Catalog in QGIS?
> > /Cheers
> You will probably need to override the GDAL command in the bottom box
> with the pencil icon. The gui only has a limited subset of options.
> http://www.gdal.org/gdalbuildvrt.html
> *.tif is allowed as the input file, which would do all tifs.
> The other approach is to create a list of all files you want to include
> 1st.
> Enjoy,
> Alex
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150205/308335a3/attachment.html>
