[Qgis-user] LecoS
Mike Treglia mtreglia at gmail.com
Sun Feb 22 15:53:17 PST 2015
Also, pretty sure on windows you need to use 32 bit for SciPy.  It's pretty easy to get data into Fragstats from QGIS too as an alternative... http://www.umass.edu/landeco/research/fragstats/fragstats.html
> On Feb 22, 2015, at 3:41 PM, Alex Mandel <tech_dev at wildintellect.com> wrote:
> I believe OSGeo4W includes Scipy. If you used the QGIS standalone
> installer you probably don't have it.
> http://gis.stackexchange.com/questions/50464/how-to-install-scipy-for-qgis-standalone
> So it doesn't have to be super hard.
> Thanks,
> Alex
>> On 02/22/2015 01:31 PM, Susan Iremonger wrote:
>> Thanks for that, sadly I think that sounds a bit beyond my capabilities. I
>> am using Windows 8.1. I shall look into it further and see if I can get
>> some advice on how to do that. Thanks.
>> Susan.
>> On Sun, Feb 22, 2015 at 9:24 PM, Alex Mandel <tech_dev at wildintellect.com>
>> wrote:
>>>> On 02/22/2015 01:19 PM, Susan Iremonger wrote:
>>>> Hi, first time using this mailing list, apologies if I am making errors
>>>> with whom to sent it to. I am asking for info about a plugin called
>>> LecoS -
>>>> Landscape Ecology Statistics. When I tried to load it (I am using QGIS
>>>> Brighton)  I got a message "The plugin is broken. No module named scipy".
>>>> Does anyone know anything about the plugin and how it can be got working?
>>>> Thanks.
>>>> Susan
>>> You have to install the Python Scipy library to the same python that
>>> QGIS uses. Installation of python libraries depends on what operating
>>> system you are using.
>>> Thanks,
>>> Alex
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150222/b8d3f333/attachment.html>
