[Qgis-user] print composer and atlas feature on large dataset
Alexandre Neto
senhor.neto at gmail.com
Thu Feb 26 04:33:35 PST 2015
Hello matteo,
Can you send me a sample you your dataset, so I can do some tests?
thanks,
Alexandre Neto,
PS: I will only be able to work on a proper solution tomorrow, I will leave
a partial answer on gis.stackexchange meanwhile.
On Thu, Feb 26, 2015 at 10:46 AM, Matteo Ghetta <matteo.ghetta at gmail.com>
wrote:
> Thanks! :)
> I hope you'll get an answer..
> please tell me if you need a subset of my data..
> Cheers
> Mattep
> 2015-02-26 11:14 GMT+01:00 Alexandre Neto <senhor.neto at gmail.com>:
>> Nice challenge!
>> I will try to think of a good answer.
>> Alexandre Neto
>> On Thu, Feb 26, 2015 at 9:55 AM, Matteo Ghetta <matteo.ghetta at gmail.com>
>> wrote:
>>> Hi guys,
>>> I raised up this question on stackoverflow some times ago, but no answer
>>> yet, maybe someone can help me..
>>> http://gis.stackexchange.com/questions/135834/print-composer-and-atlas-feature-on-large-dataset
>>> does somebody ever had a similar problem?
>>> Basically the question is if one can use the atlas in order to print
>>> several layout depending on different styles (categorization based on
>>> different attributes) of a layer..
>>> Thanks!
>>> Matteo
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150226/f14ebdf5/attachment.html>
