[Qgis-user] WFS-T update to geoserver fails
Scott
sctevl at gmail.com
Fri Feb 27 09:51:37 PST 2015
Maxx,
This matches my own experiences with trying to edit a WFS-T from
GeoServer using QGIS. I typically get an error saying unexpected html
response or something to that effect. The edits will make it into the layer
in GeoServer but will not update in QGIS on commit (just like you have
seen).
I'm using GeoServer 2.6 (but it's consistent for 2.4, and 2.5) and QGIS
2.6 (also a problem since 2.2 at least). The GeoServer is on an Ubuntu VM
so I don't believe this is unique to AWS deployments.
Scott
On Fri, Feb 27, 2015 at 11:36 AM, emmexx <emmexx at tiscalinet.it> wrote:
> Il 01/27/2015 03:05 PM, Richard Duivenvoorde scrisse:
>> Geoserver has a lot of debug levels, try to raise the debuglevel to see
>> what comes in at geoserver?
>> As I've used QGIS in combi with WFS-T before ad your osgeo live setup is
>> succesfull, my first guess is the Boundless Geoserver, but I could be
>> wrong.
> I get back to this thread because I made no or very little progresso on
> this.
> I tried to use a new server. I created an instance of AWS Elastic
> Beanstalk. To service let you run an app by creating an instance of an AWS
> virtual server, running on top of it java, tomcat 7 and geoserver 2.6.2.
> (the official edition, not boundless)
> I didn't modify anything in geoserver, I only changed the debug level.
> In qgis I added a new wfs server, with that new server there are no more
> problems when updating, the wfs service doesn't stop after committing.
> I loaded the Tasmanian Roads layer.
> I tried to add new features, updating existing features (only the
> geometry), updating only attributes of an existing feature, updating both
> attributes and geometry of an existing feature.
> I get no error only when committing an update of an attribute, with no
> change to the geometry.
> In all the other cases I get a timeout (?) error:
> Provider errors:
> Empty response
> If I reload the layer, in general I find that the changes were committed.
> At the end of this message I add the geoserver log when adding a new
> feature.
> As I already posted in another thread, I got inconsistent results when
> splitting features.
> I used qgis on my slackware 14.1 and on windows 7 getting the same results.
> I wonder if AWS servers have some special settings that make them unusable
> with geoserver and QGIS.
> Unfortunately, at the moment QGIS is unusable for editing data on my
> geoserver.
> Any suggestion is welcomed.
> Thank you
> maxx
> 2015-02-27 16:07:48,672 DEBUG [org.geoserver.security] -
> AuthenticationCache found an entry for basic, admin:
> bfa584f5598433a3c1fe16b00acc9c43
> 2015-02-27 16:07:48,672 TRACE [org.geoserver.ows.OWSHandlerMapping] - No
> handler mapping found for [/wfs]
> 2015-02-27 16:07:48,673 TRACE [org.geoserver.ows.OWSHandlerMapping] - No
> 2015-02-27 16:07:48,673 DEBUG [org.geoserver.ows.OWSHandlerMapping] -
> Mapping [/wfs] to HandlerExecutionChain with handler
> [org.geoserver.ows.Dispatcher at 6ccf6ecc] and 1 interceptor
> 2015-02-27 16:07:48,674 DEBUG [org.vfny.geoserver.requests] - First 4
> bytes of XML doc are : 3C ('<') 54 ('T') 72 ('r') 61 ('a')
> 2015-02-27 16:07:48,674 DEBUG [org.vfny.geoserver.requests] - Charset
> detection phase 1. Inferred encoding: UTF-8
> 2015-02-27 16:07:48,674 DEBUG [org.vfny.geoserver.requests] - Invalid(?)
> XML declaration: <Trans.
> detection phase 2. Charset in XML declaration is `null`.
> 2015-02-27 16:07:48,674 DEBUG [org.vfny.geoserver.requests] - Trying to
> create reader basing on existing charset information: `UTF-8`.
> 2015-02-27 16:07:48,674 DEBUG [org.geoserver.ows] - Raw XML request:
> <Transaction xmlns="http://www.opengis.net/wfs" xmlns:xsi="
> http://www.w3.org/2001/XMLSchema-instance" version="1.0.0" xmlns:topp="
> http://www.openplans.org/topp" service="WFS" xsi:schemaLocation="http://
> www.openplans.org/topp http://default-environment-
> h2ymykfmrd.elasticbeanstalk.com/wfs?SERVICE=WFS&
> VERSION=1.0.0&REQUEST=DescribeFeatureType&
> TYPENAME=topp:tasmania_roads&SRSNAME=EPSG:4326&
> username=admin&password=geoserver" xmlns:gml="http://www.opengis.
> net/gml"><Insert xmlns="http://www.opengis.net/wfs"><tasmania_roads
> xmlns="http://www.openplans.org/topp"><TYPE xmlns="http://www.openplans.
> org/topp">qgis2</TYPE><the_geom xmlns="http://www.openplans.org/topp"><gml:MultiLineString
> srsName="EPSG:4326"><gml:lineStringMember><gml:LineString><gml:coordinates
> cs="," ts=" ">145.65235964938219126,-41.51154335626732461
> 146.15953266438796732,-41.68750134106524285 145.54367971759523925,-42.2153752954590118
> 146.26303736132794597,-42.58799220444284828 146.26303736132794597,-42.
> 58799220444284828</gml:coordinates></gml:LineString><
> /gml:lineStringMember></gml:MultiLineString></the_geom></
> tasmania_roads></Insert></Transaction>
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150227/bab8acc4/attachment.html>
