[Qgis-user] cartogram plugin
friedtj at free.fr friedtj at free.fr
Thu Jan 1 01:47:27 PST 2015
I am afraid I do not have the skills for long term maintenance, so providing a quick
hack through the mailing list seemed better than keeping the issue unresolved. What
I am missing here is a reference dataset to check whether a modification in the source
code of the plugin affects its behaviour. On the convex dataset I was considering the
result was not as nice as could have been expected from the illustration found at
http://anitagraser.com/2010/11/13/creating-cartograms-with-qgis-cartogram-creator/ whose
dataset I do not have access to. I am currently running the plugin on a world population
dataset as found at http://thematicmapping.org/downloads/world_borders.php to check on
a non-convex map whether the result matches expectations, but a reliable testbed would
be better suited. As an example which hints at proper operation of the plugin, the
2005 world population map becomes http://jmfriedt.sequanux.org/world_cartogram.png with
purple the original dataset, green 10 iterations and greyish blue being 27 interations.
If such a result seems relevant, maybe some knowledgeable user can comment on the figures
of http://jmfriedt.sequanux.org/lm_cart.pdf in which the Voronoi polygon map generated from
discrete measurements (train travel time in France, Fig. 1) becomes the cartograms of Fig. 4
which do not seem that informative to me. Is this an known artefact from convex maps ?
(obviously a diffusion algorithm applied to a convex dataset ends up generating a cicular
map I assume).
Happy new year, JM
----- Mail original -----
De: "Richard Duivenvoorde" <rdmailings at duif.net>
À: friedtj at free.fr, Qgis-user at lists.osgeo.org, "carson farmer" <carson.farmer at gmail.com>, kikkocristian at gmail.com
Envoyé: Jeudi 1 Janvier 2015 09:29:50
Objet: Re: [Qgis-user] cartogram plugin
On 30-12-14 09:39, friedtj at free.fr wrote:
> trivial comment concerning the Cartogram Plugin:
as the original author is Carson Farmer, and apparently people ask for
this plugin, I'm wondering if it is maybe an idea to put this plugin in
the main QGIS plugin repository.
And if Carson does not have time to do the maintaining of the plugin, we
ask one of the users to maybe do the maintenance?
@Carson: what's you opinion about that?
@Others: any volunteers?
We every now and then have plugins for which there is interest, but the
original author lost interest, of just does not find time anymore to
invest it in responding to questions or doing trivial fixes if needed
for a new QGIS version.
So in general: in these cases: please try to contact the original author
and see if you can maybe take over the maintainer ship of such a plugin?
In this case for example it looks like some lines of code would make it
usable again for QGIS users...
Active central maintenance and availability via plugins.qgis.org is
better then scattered fixes over mailing lists and GisStackExchange/
Any takers, IF Carson agrees?
Regards,
