[Qgis-user] projection center
JoeLemonnier jlemonnier at mac.com
Sun Jan 4 08:15:27 PST 2015
Wow! Thank you for such a quick response. I had been using a custom CRS without the reconfigured WGS84. It left horizontal connecting lines across the page.
I will try reconfigure the WGS84 shape file today  though the instructions were a bit unclear to me.
I know they were step by step but still were unclear.
Thanks for your patience.
Joe
Sent from iPhone
> On Jan 4, 2015, at 1:28 AM, Andre Joost [via OSGeo.org] <ml-node+s1560n5179915h25 at n6.nabble.com> wrote:
> Am 04.01.2015 um 00:47 schrieb JoeLemonnier:
> > How do I shift the center of projection.
> > For instance:
> > 1) how would I make a map of the Bering Straits , showing Russia on the left
> > and Alaska on the right.
> > 2) How would I make a world map centered at 11 degrees so that the
> > continents are unbroken.
> This might help you on the way:
> http://gis.stackexchange.com/questions/70411/qgis-display-world-country-shape-files-centered-on-pacific-ocean-using-robinson
> HTH,
> André Joost
> Qgis-user mailing list
> [hidden email]
> If you reply to this email, your message will be added to the discussion below:
> http://osgeo-org.1560.x6.nabble.com/projection-center-tp5179904p5179915.html
> To unsubscribe from projection center, click here.
> NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/projection-center-tp5179904p5179932.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150104/77002571/attachment.html>
