[Qgis-user] export coordinates in diferent src
Andre Joost
andre+joost at nurfuerspam.de
Sat Jan 10 03:29:50 PST 2015
Am 10.01.2015 um 11:17 schrieb daniel pinto:
> hello i have a poligon wit 120 vertices and i have the coordinates in wgs
> 84 espg 4326
> i need the same coordinates im the atribute table in utm 33s espg 32733
> is it possible to export them in this src and add to the atribute column
> witout usic coordinate capture and doing it one by one???
You have to save your layer using rightclick, Save As... to another name
and EPSG:32733, and add the result to the canvas. From that, you can
export the vertex coordinates to CSV with the mmqgis plugin.
For a polygon, you will not get the coordinates into the attribute
table, because the whole polygon has only one row in the attribute
table. You can get coordinates in the attribute table only for point layers.
HTH,
André Joost
