[Qgis-user] importing Text from dxf file
Andreas Neumann a.neumann at carto.net
Mon Jan 12 04:04:31 PST 2015
There is certainly room for improvement regarding DXF. We first
concentrated on the DXF export, which is in already quite good shape in
QGIS master. Once this is done, we should invest in DXF reading as well.
Until then, there are only workarounds, sorry.
Andreas
Am 2015-01-12 12:36, schrieb Siki Zoltan:
> Dear Giacomo,
> yes, that is the way what you found. There is no text/annotation
> support in most of the GIS formats (e.g. shape file, PostGIS,
> SpatiaLite, etc.).
> You can make a label from the Text column. What is not imported from
> the DXF file are the angle, size and font of the text.
> Best regards,
> Zoltan
> On Mon, 12 Jan 2015, Giacomo Minotti wrote:
>> Good morning,
>> is it possible to import in qgis a dxf file that contains text?
>> When I import the file, i see the text like point
>> thanks
>> Giacomo
> Qgis-user mailing list
