[Qgis-user] Re : Edit print composer
Junior delazj at gmail.com
Tue Jan 13 00:02:37 PST 2015
Hi Matt,
Once you have activated all the layers that should be displayed in your print composer, select the map item inside your print composer and check the option "lock layers for map item" in the properties tab.
More info can be found below "Composer Items" chapter in this link http://docs.qgis.org/2.6/en/docs/user_manual/print_composer/print_composer.html
Envoyé depuis mon HTC
----- Reply message -----
De : "Matt Boyd" <mattslists at gmail.com>
Pour : "qgis-user" <qgis-user at lists.osgeo.org>
Objet : [Qgis-user] Edit print composer
Date : mar., janv. 13, 2015 06:02
Hi QGISers,I've got a few different print composers in the same project and it's slightly painful to go back and turn layers on/off when I want to edit one of them.
Is there an easy way to turn on/off the layers in a particular print composer automagically?
THanks
Matt
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150113/476bed6f/attachment.html>
