[Qgis-user] Processing: how to use input parameter in "Select by expression"
    Andreas Neumann
    a.neumann at carto.net
    Thu Jan 15 21:34:22 PST 2015
In QGIS processing I would like to do the following:
Input Parameters:
- Vector Layer
- Numeric input parameter (year)
Use the "select by expression" algorithm.
Question: how can I use the value of the "year" input variable to be
used in the expression. Is there a special syntax to retrieve the values
of input parameters?
Thanks a lot!
Andreas
