[Qgis-user] Postgres arrays in QGIS and form widget
Bernhard Ströbl bernhard.stroebl at jena.de
Thu Jan 15 22:50:38 PST 2015
Hi Olivier,
about editing arrays: Your request made me extent my plugin
DataDrivenInputMask so it supports array field types. Currently this
extended version is in a separate branch [1]. It supports arrays of type
char, varchar, integer, decimal, date and boolean. Please test and
report any issues in [2].
Bernhard
[1] https://github.com/bstroebl/DataDrivenInputMask/tree/supportArray
[2] http://hub.qgis.org/issues/11978
Am 15.01.2015 20:22, schrieb Olivier Dalang:
> Hi,
> Thanks for your answers.
> Of course, I could do that with relations, but in my specific case I
> prefer to keep everything in one table (I have some fairly complex
> triggers to keep versions history and restrict some operations and have
> no need for separate tables).
> But I'll have a look at the link you provided, and I also found this in
> the meantime :
> https://woostuff.wordpress.com/2011/09/05/qgis-tips-custom-feature-forms-with-python-logic/
> It seems that with this, there's no limit ;)
> Bests,
> Olivier
> 2015-01-12 8:51 GMT+00:00 Matthias Kuhn <matthias.kuhn at gmx.ch
> <mailto:matthias.kuhn at gmx.ch>>:
>     Hi Olivier,
>     There is some support for this in the value relation widget. If you
>     allow multiple selections, it will make use of the array notation,
>     storing multiple foreign keys ( { fk1, fk2, fk3 } ).
>     If you want to get further support for this, you could write your
>     own form elements which is possible for some time (although I
>     haven't seen it widely used).
>     http://blog.vitu.ch/10142013-1847/write-your-own-qgis-form-elements
>     For your last use-case "same number of items" you should consider to
>     normalize your database and and have two tables linked with a
>     foreign key.
>     CREATE TABLE lots(
>        id serial,
>        common_data text
>     CREATE TABLE person(
>        id serial,
>       first_names text,
>       last_names text,
>       age int,
>       group integer REFERENCES lots(id)
>     Matthias
>     On 01/11/2015 03:17 PM, Olivier Dalang wrote:
>>     Hi !
>>     Postgres' arrays are a great feature. They allow store several
>>     values in one field :
>>     CREATE TABLE lots(
>>         id serial,
>>         owners text[]
>>     INSERT INTO lots(owners) VALUES( ARRAY['john','mike','jenny'] );
>>     But is there a way to edit this cleanly in QGIS with the forms ?
>>     Natively, the form widget will be a plain text input, and the
>>     value will display like this
>>     {"john","mike","jenny"}
>>     This is more or less usable for text fields, but not really clean,
>>     since the user needs to escape some characters, and it's not very
>>     readable. But then it's impossible to use with other widgets
>>     (checkbox, range, etc.)
>>     I'd love to have a dynamic input where the user could add and
>>     remove fields, and where QGIS widget types could be used.
>>     Actually, I'd even need a form where I'd have the same number of
>>     items for several arrays, and where adding/removing an item would
>>     work on several field at once, to work on a table like this :
>>     CREATE TABLE lots(
>>         id serial,
>>         first_names text[],
>>     last_names text[],
>>         age int[]
>>     Is there a way to do it ?
>>     Maybe with python ?
>>     Has anyone of you already done this and would agree to share ?
>>     Any pointer in the right direction would be very welcome !
>>     Thanks a lot in advance,
>>     Olivier
__________ Information from ESET Mail Security, version of virus signature database 11023 (20150116) __________
The message was checked by ESET Mail Security.
http://www.eset.com
