[Qgis-user] Nodata and raster calculator
    Nicolas Cadieux
    nicolas.cadieux at archeotec.ca
    Wed Jan 21 19:42:18 PST 2015
I also have been doing it manually. There should be an option in the Qgis calculator for that but I did not find it.
 Hopefully, someone will both teach us something new if the option exists...
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112  Fax: 514.381.4995
Le 2015-01-21 15:23, "jfprieur [via OSGeo.org]" <ml-node+s1560n5182962h83 at n6.nabble.com> a écrit :
	Hello,
I am using QGIS 2.6.1 raster calculator to mask a curvature raster to exclude a range of values. I am following the instructions at
http://docs.qgis.org/2.6/en/docs/user_manual/working_with_raster/raster_calculator.html and am getting the proper output. My question is: Is it possible to output the nodata value instead of 0 (which is what the result is in the example) for the excluded values?
I am using floating point rasters which default to a 3.whatever e-38 nodata value which means that I have to change the nodata manually after to 0 (which sometimes causes additional problems with borders, etc.)
I may also be doing this completely wrong, strong possibility.
		If you reply to this email, your message will be added to the discussion below:
		http://osgeo-org.1560.x6.nabble.com/Nodata-and-raster-calculator-tp5182962.html
		To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
		To unsubscribe from Quantum GIS - User, click here .
		NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Nodata-and-raster-calculator-tp5182962p5183012.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150121/9cc89752/attachment.html>
