[Qgis-user] R: R: Re: Aerograms style
labiancamarilena at libero.it labiancamarilena at libero.it
Fri Jan 23 03:40:04 PST 2015
For the example the complete link is:
http://www.cartografia.regione.lombardia.
it/oopp/html/help/images/mappaHideShowLabel.png
>----Messaggio originale----
>Da: labiancamarilena at libero.it
>Data: 23/01/2015 12.36
>A: <tech at wildintellect.com>, "Andre Joost"<andre+joost at nurfuerspam.de>, <qgis-
user at lists.osgeo.org>
>Ogg: [Qgis-user] R: Re:  Aerograms style
>Hi,
>I meant that I have seen in several atlases that on map instead of changes
in
>color were pie charts with variable dimensions showing the intensity of a
>phenomenon.
>I do not know if I explained well.
>This is an example:
>Thanks a lot
>Marilena
>>Da: tech_dev at wildintellect.com
>>Data: 22/01/2015 21.24
>>A: "Andre Joost"<andre+joost at nurfuerspam.de>, <qgis-user at lists.osgeo.org>
>>Ogg: Re: [Qgis-user] Aerograms style
>>On 01/22/2015 12:02 PM, Andre Joost wrote:
>>> Am 21.01.2015 um 20:16 schrieb
>>> labiancamarilena at libero.it:
>>>> Dear all, I would like to customize the map using the style as
>>>> aerograms to show the intensity of a phenomenon, but I do not find
>>>> this option in QGIS. Can anyone help me?
>>> I am not sure what you mean by aerogram style.
>>> You can use a categorized or graduated style with colour ramps of reds,
>>> greens or blues on the data field you want to visualize, and add some
>>> transparency if you want to have a basemap shining through.
>>> HTH,
>>> André Joost
>>Did you mean something like this:
>>http://www.nasa.gov/images/content/583575main_Fig.%203.jpg
>>With the arrows showing direction and magnitude?
>>Thanks,
>>Alex
>>_______________________________________________
>>Qgis-user mailing list
>>Qgis-user at lists.osgeo.org
>>http://lists.osgeo.org/mailman/listinfo/qgis-user
